Home > Forums > Software User Forums > AVL FIRE
AVL Fire-m edge mesh partially remove
Like Tree1Likes
  • 1 Post By turaj
Old   January 4, 2022, 23:43
Default AVL Fire-m edge mesh partially remove
Lee Hyo Kyoung
LEEHK is on a distinguished road
Hi.
When I detect edge on surface geometry, bad quality edges are made and i want to exclude bad edges. (like short edges, complicated edges...)
I used the tool which is 'Remove Bad edges' in Discrete CAD menu.
But this tool doesn't work well and can't find bad edges that i want to remove.
I want to do select bad edges manually and remove partially.
What should I do?
Thank you.
LEEHK is offline   Reply With Quote
Old   January 25, 2022, 04:54
turaj
turaj is on a distinguished road
select bad edge in edge selection, active them and (in view ) cut them
LEEHK likes this.
turaj is offline   Reply With Quote
Old   February 14, 2022, 19:22
Smile
Lee Hyo Kyoung
thank you for reply, i did select bad edge and click remove button in edit ribbon. It works well
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 14:41
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
