Trandat errors
I am working with Avl internal chemkin solver I encountered an arror that is
" %fire-F-cthgtr_ck, species O3 not found in transport database. please check name! the file "trandat" must be located in the directory where the executable is called. " I located trandat in the directory and added the O3 in trandat file but the error not vanished ?? |
Did you solve your problem yet?
Is species 03 important to your result if not you can always ignore that species by putting it in "do not solve equation for species number" and try running the simulation.
If species is important for your calculation then just adding it in trandat file will not solve the problem you will have to find the reaction and trandat file which can calculate for that species. If your using avl fire 2014.2 I can help you with that files Sent from my Redmi Note 3 using CFD Online Forum mobile app |
Please check whether you have checked external (not "internal") option in fluid properties panel.
