Home > Forums > Software User Forums > AVL FIRE
Where does my simulation diverge?
Old   October 5, 2018, 06:20
Default Where does my simulation diverge?
Stephan Werner
swerner0711 is on a distinguished road
Hello everyone,
is there a way to find out where exactly a problem diverges? Or how can I find out, what causes my problem to diverge?
I am currently simulating a gasoline motor, 720 degree cank angle. At the BDC the problem diverges, I doublechecked the SST but can't find the error. By lowering relaxation factors and increasing the amount of iterations I get the simulation to run 2 more degrees, but I think there should be a less calculation intense solution, rather than working around the problem by lowering relaxation factors even more and increasing the number of iterations.
I'ld be thankful for any hint on how to figure out, what exactly causes the problem to diverge.
Also, what cell are the values in the .fla file and 2D-log taken from?
swerner0711 is offline   Reply With Quote
simulation supersonic external flow arround the missile diverge!! raminostadi FLUENT 2 April 14, 2018 12:13
Simulation stops at simulation but doesn't diverge mpirun error Dar87 OpenFOAM Running, Solving & CFD 0 March 28, 2018 03:52
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 02:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 15:06
DISS causes simulation to diverge Cb Siemens 1 October 21, 2005 05:45
