-   AVL FIRE (https://www.cfd-online.com/Forums/avl-fire/)
-   -   Divergence in calculation: water-emulsion-injection (https://www.cfd-online.com/Forums/avl-fire/208075-divergence-calculation-water-emulsion-injection.html)
Dennniem October 8, 2018 11:30
I am simulating a water-emulsion-injection in an 4 stroke gas engine.
The Mesh was build with Fame Engine Plus.
srokes:
- 315°-526°: exhaust valves open
- 526-534°: valve overlapping
- 534°-772: intake valves open
- 772°-1035: all valves open
The problem is, that my calculation diverges around 360°CA (exhaust valves not full open).
The false report are such as:
- Problem diverges: TKE equation, variable: TKE, material: 1
or
- Problem diverges: continuity equation, variable: Pressure correction, material: 1
The following modules are activatated: Species Transport, Combustion, Spray, Wallfilm, Thin Walls.
When the modules Spray, Wallfilm and Thin Walls are deactivated, the problem are the same. So I think the problem is an incorrect setting in the solver control.
I have decreased the underrelaxation factors (pressure: 0.1, Momentum: 0.6, TKE: 0.3, Turb. diss. rate: 0.3. I also have tried to change the linear solver of continuity (GSTB/AMG and variated th max iterations), but the problem was still the same.
Here are other settings, which I used:
- Convergence Criteria Pressure: 0.01
- Boundary Condition Inlet: total pressure 1.5bar
- BC outlet: static pressure 1.07bar
It is possible, that the problem for the divergence is the mesh itself?
I use high refinements in valve seats and valve heads.
I am thankful for every recommendation.
Best regards
swerner0711 October 9, 2018 03:30
did You do a dummy run after meshing with FE+? What were the results?
Also a refinement of cells might be necessary, when the valves are almost closed.
Dennniem October 9, 2018 05:24
The result of the dummy run were 2 twisted faces.
5°CA after the valves opened and before the valves will close I have used a refinement level 3 at valve heads and the valve seats.
My settings of the refinements are a recommendation of an example case in AVL Fire (case 920)
