AVL Fire ESE DIESEL- importing piston design
I am trying to import a piston geometry *dxf file, however there is an error code sating('axis' edge is not made of one edge in piston model).
The piston bowl designed is for an unusual engine with a curved piston. if anyone has ever had this problem, please can you help! Thanks |
I am having the same problem. Did you find a solution to this problem? |
