September 25, 2015, 19:38 |
Problem running simulation
Cristiano Ferreira
Rep Power: 13 |
I've been trying to run Example 900 from AVL FIRE. I've followed all required steps, but whenever I run the simulation, it simply doesn't show any 2D log. It freezes many options and the case becomes completely unuseful. I sent my case to a colegue and he ran it without a problem on a different computer. I've tried to run in different Windows platforms but it also didn't work. I'm attaching a screenshot taken after I pressed "Start Calculation" so you can see how the program becomes. Please, I'd appreciate any help on this.
March 12, 2017, 05:20 |
asghar
i have the same problem.... help me!!!please
March 12, 2017, 11:20 |
mohammad meftah
Rep Power: 9 |
i have same problem
any one can help? |
March 13, 2017, 04:59 |
asghar
are u iranian?
March 13, 2017, 19:02 |
mohammad meftah
Rep Power: 9 |
March 18, 2017, 18:45 |
Check .fla file
Have you check the output inside your case folder. Look for the .fla-file in $yourFolder$/Calculation/$yourCaseName$/ directory. It may contain useful informations. If it doesn't exist, check which files are listed in this folder.
April 23, 2017, 07:16 |
engine_sim
Rep Power: 8 |
I use ese diesel and was facing problem similar to that. I solved it just by copying the project directory to c:\ and it started running smoothly.
Sent from my Redmi Note 3 using CFD Online Forum mobile app |
April 25, 2017, 12:40 |
#8 | |
Laurel
Rep Power: 9 |
April 25, 2017, 12:41 |
#9 | |
Laurel
Rep Power: 9 |
April 25, 2017, 12:50 |
#10 | |
engine_sim
Rep Power: 8 |
Email me to jay.h.chhatbar@gmail.com some details of your simulation. Sent from my Redmi Note 3 using CFD Online Forum mobile app |
April 25, 2017, 12:52 |
#11 |
Laurel
Rep Power: 9 |
okay thanks my name is laurel by the way
April 25, 2017, 12:53 |
#12 | |
Laurel
Rep Power: 9 |
April 25, 2017, 13:20 |
#13 |
Laurel
Rep Power: 9 |
okay i just sent you an email on laurelowanate@gmail.com.
I would be very grateful if you could reply with some good news |
April 9, 2021, 11:24 |
#14 |
turaj
Rep Power: 4 |
May 6, 2021, 18:12 |
#15 |
Lukas Kutej
Rep Power: 10 |
some hints...
- let run it single not mpi... check workload - in Case directory check .fla file. there is output of residuals, summaries or errors - in Case directory check for hidden files. .isrunnung isstopping ...just delete those hidden file and rerun. you can also delete cfdsolver from case directory if you are using astlaunscher... there could be also error message in home directory in hidden folder .avl |
January 25, 2022, 06:01 |
#16 |
turaj
Rep Power: 4 |
your mesh and your case must be same name and u copy your project where you install avlfire.
Display Modes | |
Continuous casting simulation problem | luke.christ | FLUENT | 6 | November 24, 2020 08:14 |
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 03:11 |
Pressure dissipation problem in bubble simulation (Riemann problem) | ndabir | CFX | 9 | June 4, 2015 17:48 |
[CFX] Simulation of Flow Separation in a rectangular diffuser - Convergence Problem | anon_b | CFX | 11 | May 6, 2012 21:16 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
