Hull resistance analysis Residual problem
Old   September 30, 2013, 06:13
Default Hull resistance analysis Residual problem
Sdk
sdkozm is on a distinguished road
Hi friends...
I have a problem with my simulation. I try to calculate hull resistance, and the brief information about my simulation is that:
about 1.2 million elements
time step: 0.01 sn
iteration: 8
And the problem is that: Tke and water residuals don't convergence. momentums and continuity is 10^-3 or 10^-4
If there is any one to help me, I am so glad...
sdkozm is offline   Reply With Quote
Old   October 1, 2013, 14:50
Post
rock_bottom is on a distinguished road
Might be a problem with the BC you apply!!
rock_bottom is offline   Reply With Quote
Old   October 3, 2013, 04:10
Unhappy please help
Sdk
sorry could you explain what is BC?
Is it boundary condition?
If it is,
Sides is symmetry plane,
Top is slip Wall
floor is velocity inlet
presure outlet
and velocity inlet
finally all hull components are Wall
Old   October 8, 2013, 08:40
Jan Willem Krijger
Sideshore is on a distinguished road
First of all, the residuals in Star-CCM+ are made non-dimensional with respect to the start of the simulation. Therefore it can be hard to check convergence by using the residuals, especially for multiphase flows, often it is more convenient to look at the forces (the resistance for example).
Your BC seems alright. I normally use:
Velocity inlet for:
Inlet, Bottom, Top, Sides
Pressure outlet for:
Outlet
If the figure you are showing is the complete domain, you might want to increase the length behind the vessel and give the waves more time to damp. You can either damp the waves by increasing your cell size or by using the VOF damping option (see the manual).
Good luck!
Sideshore is offline   Reply With Quote
Old   October 8, 2013, 12:00
Sdk
First of all thank you for your reply. The forces converge.
But,
When I use velocity inlet BC for sides after about 5000 iterations later sdr value increase more and more.
What does it mean? Besides if you want I can send you my simulation file, I hope, I don't disturb you.
Thank you again...
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 10:54
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 02:09
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
