Home > Forums > CD-adapco
Solid interface
Old   November 24, 2015, 15:59
Default Solid interface
Nesrine Bouhrira
NesrineB is on a distinguished road
hi,
my geometry includes a tube with a fluid circulating inside it and a braid of solid around it. So I have solid-solid conduction and solid-fluid conduction. I set up the mesh and the interfaces between the fluid-solid region and solid-solid region with CCM+ but the mesh didn't generate. Does it have a problem with the interfaces ? Is it ok to set up two different meshes ?
Thank you.
NesrineB
NesrineB is offline   Reply With Quote
Thread Tools
Trackbacks are On
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
how the interface between 2 solid regions is treater in chtMultiRegionFoam ? Cyp OpenFOAM 1 June 16, 2010 16:03
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
