relaxation factors
Old   October 25, 2000, 11:02
Default relaxation factors
Roberto Ciardulli
How do relaxation factors affect calculations? If I use values that are lower than default ones, is my solution "less real"?
thank you in advance
Roberto
Old   October 25, 2000, 11:35
Default Re: relaxation factors
J. Y. Luo
The relaxation factors only affect the convergence history, not the final results. The purpose of under-relaxation is to make variable changes less rapidly so that the solution is more stable.
Old   October 26, 2000, 10:40
Roberto Ciardulli
I know that this could seem a stupid question, but wouldn't it be easier just to set a very very low relax. fact. like 0.1? I'm very interested in this topic.
Thanks, Roberto
Old   October 26, 2000, 11:35
J. Y. Luo
Yes, you can do that. It's a balance between stability and computing time. If you set very low under-relaxation factor, the solution changes very little by each iteration and it will takes ages to get convergence. The best values should be as close to one as possible while maintaining solution stability.
Relaxation factors Vidya Raja FLUENT 7 September 26, 2006 20:00
Under relaxation factors for LES Dinesh Main CFD Forum 0 March 26, 2006 06:25
Under relaxation factors box... Help ! Cyril FLUENT 8 October 28, 2005 00:16
Relaxation Factors Tim Phoenics 3 June 30, 2004 02:03
relaxation factors zhujianguo Phoenics 1 August 5, 2003 06:17
