Mixing length
Old   November 13, 2000, 08:35
Default Mixing length
Sabatini
Hay people
i have one rectangular duct 50mm*50mm*4500mm, for the boundary condition at the inlet i have choose the turbulent intensity 5% but the problem what i have how i can choose the turbulent mixing length in the entrance of the duct, have somebody some suggestion or literatur for that Thanks
Old   November 16, 2000, 05:41
Default Re: Mixing length
Bo Jensen
I have seen in manuals for different CFD programs that a fully developed turbulent flow has turbulence intensity of 5% (as you use) and a mixing length of 0.1 times the hydraulic diameter.
Regards
Bo
Old   November 17, 2000, 05:25
Sabatini
Hay jensen
you mean 0.1 times the hydraulic diameter is 10% von Hydralic diameter in the entrance( i have a circular entrance von 100mm diameter. thanks
Old   December 31, 2000, 05:08
AK Balasubramanian
Hi sabatini,
If the values of the turbulent viscosity are more than one or two orders of magnitude grater than the molecular viscosity, then the you should thoroughly review the assumption and/or data used to calculate turbulence at the boundaries.
Regards,
AK Balasubramanian
mixing length lili Siemens 1 February 5, 2007 19:22
mixing length model mukkarumhussain Main CFD Forum 2 August 6, 2002 00:02
mixing length mukkarum Main CFD Forum 4 July 25, 2002 05:16
mixing length rafat FLUENT 0 June 7, 2002 04:51
mixing length moodel tomi Main CFD Forum 5 November 12, 1999 11:24
