-   Siemens (https://www.cfd-online.com/Forums/siemens/)
-   -   Computation of Lift and Drag (https://www.cfd-online.com/Forums/siemens/52513-computation-lift-drag.html)
Ramanath KS December 26, 2000 07:44
For a subsonic external flow of an object of length L, what could the suggested computational domain to capture the velocity and flow profiles well.
The inlet I thought we could define thru' velocity and outlet thru pressure conditions. Is it OK.
What is the suggested approach to compute the lift, drag, moment coefficients, Xcp in STAR-CD code
Heng Huang December 27, 2000 03:25
Re: Computation of Lift and Drag
1.You can use POSDAT.f to edit what you want. 2.The variable FORCB(I,IB) OF POSDAT.f is the global force at boundaries IB.And the index I is: I=1,X-dir I=2,Y-dir I=3,Z-dir
