Mass flow calculation across a mesh section
Old   March 2, 2001, 07:18
Default Mass flow calculation across a mesh section
Haris Maharana
Hi guys,
Can anybody please give me some idea about how to calculate the mass flow rate (not mass flux) across a particular mesh section in the flow domain in STAR-CD(excluding the boundary regions)?
Thanks, Haris
Old   March 2, 2001, 07:44
Default Re: Mass flow calculation across a mesh section
MvD
First build an appropriate cset. Define your section e.g. "spoint curs". Load velocities and densities: "getc all dens". Use integration: "intergrate cset".
You get in the last position the product A*VN*S which, with velocity as a vector and densitiy as a scalar quantity, yields the mass flow rate in [kg/s].
For two-phase flow the result might be wrong, because S is only the density of the light fluid. In this case you must take the value A*VN and do the density multiplication by hand.
In case you already know your cross sections in advance it might be more accurate to write a dedicated postdat.f function
Old   March 2, 2001, 08:53
Haris Maharana
Thanks Gentleman. Thanks for your suggestion.
Haris
Old   March 2, 2001, 08:56
Haris Maharana
Thanks Gentleman,
Thanks for your response.
Haris
Calculation of mass flow across a boundary jdk OpenFOAM Post-Processing 65 April 4, 2024 11:47
CFX:getting mass flow rate across a cross section allamaprabhu CFX 1 February 14, 2006 12:07
mass flow rate at different cross section !! Nyquist Siemens 7 September 15, 2003 12:13
Mass Flow Rate Calculation Paul FLUENT 9 March 23, 2002 08:37
mass averaged pressures across a mesh section Haris Maharana Siemens 0 March 7, 2001 04:36
