August 20, 2001, 07:48 |
defining walls in STAR-CD
When you don't apply a boundary condition to a boundary, it will automatically be defined as a wall (boundary 0 - Wall). Did anybody notice that if you explicitly define those boundaries as walls, that the convergence of the solution is changing drastically? Why is that?
Nijso |
August 20, 2001, 14:10 |
Re: defining walls in STAR-CD
You can alter the definition of the default wall boundaries by redefining region 0 and you can also change the wall properties of any defined wall by defining the appropriate region number (RDEFINE command). Are you absolutely sure that the walls you defined have exactly the same properties as the default walls?
August 22, 2001, 09:24 |
I have a convergence problem, but I have not noticed this. What is your version? Is it for pc or unix? I'll try some cases.
Giovanni |
August 22, 2001, 12:11 |
I'm running on Sun/solaris, version 3.101 It seems that it does not do this in general, I tried some other simple configurations. I'm doing a simulation with 2-D axisymmetric flow with swirling inlet conditions, the inlet is about 1/2 the radius of the pipe.With this configuration, it's convergence is different. I have not isolated the exact source of the problem yet... Nijso
Use wall function on some walls (not all walls) | Mahdi10 | FLUENT | 1 | February 16, 2009 12:52 |
HTC for low Y+ walls | Tang | FLUENT | 0 | March 15, 2007 16:55 |
too many walls?? | matze | Siemens | 2 | March 1, 2006 08:13 |
STAR CCM+ Defining problem | tn | Siemens | 2 | February 9, 2006 11:22 |
