Sub-supersonic un-steady outlet
Old   August 31, 2001, 09:23
Default Sub-supersonic un-steady outlet
F.Lombardi
What is the correct boundary to apply at the outlet when the inlet velocity varies rapidly from subsonic to supersonic conditions? 'Outlet'condition produces negative densities when flow is subsonic. Thanks.
Old   August 31, 2001, 14:28
Default Re: Sub-supersonic un-steady outlet
John C. Chien
(1). The correct boundary at the out let is the one which simulate your real "testing" condition. (2). In other words, your computational domain must be consistent with the real testing configuration. (3). When the flow is "subsonic", the region of influence is infinite, that is, it can reach almost everywhere. In that case, the selection of the outlet location is critical. Move it further away from the point of interest. (4). If the code is producing negative densities, then it is not a realistic code at all.
Supersonic Steady Inviscid flow over a cone Kartik Bulusu FLUENT 2 October 1, 2013 04:21
Outlet pressure in a supersonic flow chouki FLUENT 3 August 16, 2007 10:05
Boundary Condition at outlet for supersonic flow Benjamin Zachariah FLUENT 4 April 22, 2007 23:47
Supersonic and subconic outlet Dmitry CFX 3 April 2, 2007 17:04
Creating reversed flow at a supersonic outlet Stephen FLUENT 2 January 3, 2003 10:52
