August 30, 2001, 13:20 |
User specified k-e model
Hi everyone,
I use StarCD to model laminarising flow in a heat exchanger, and I would like to implement a low Reynolds-number k-e model through the sorkep.f and vistur.f routines. However, when specifying the use of the subroutine for turbulent viscosity vistur.f, the equations for k and epsilon are somehow inactivated. Unfortunately it is not possible to reactivate epsilon. Does user-specification of the entire turbulence model require special settings I may not be aware of? I would greatly appreciate your advice, Jasper Ps: It would of course be possible to implement k and epsilon using scalars (and have better control on k-e boundary definition), but that would exclude the use of cyclic boundaries. |
August 31, 2001, 11:38 |
Re: User specified k-e model
look here: http://www.stanford.edu/~gmedic/cooling.html
September 5, 2001, 05:08 |
Thanks, I have spoken to Jeong Min Seo. I hadn't realized switch 12 alone invoked vistur.f (Usefull, if you do not want Star to default to VIST = 0.01*VISM in laminarising flow),
Cheers, Jasper |
User Defined Real Gas Model | john | FLUENT | 1 | October 25, 2012 14:05 |
Wall Treatment of User defined Turbulence Model | Yang Chung | FLUENT | 0 | August 23, 2008 11:31 |
Casson Viscosity model as one user define function | Zahra Rahmdel | FLUENT | 0 | November 6, 2004 05:53 |
User viscosity routine and user scalars? | Jeff | Siemens | 3 | January 6, 2003 05:26 |
Problem With User-Defined Fan Model Panel | neihad | FLUENT | 0 | November 25, 2001 17:21 |
