extracting the subtitle
Old   September 21, 2001, 13:52
Default extracting the subtitle
Joern Beilke
Is there a way to extract the subtitle from an existing case using a script? Usually cdsave can be used to get information about most settings in the .mdl file, but the subtitle is not saved there.
Next problem: is there a command to list all existing plla's with the contents, position, ...
Old   September 24, 2001, 08:45
Default Re: extracting the subtitle
steve
If you do a "status" while in the plot module, it will list all plla's with complete information. I don't think there is anyway to extract the subtitle.
Old   September 24, 2001, 09:12
Jon
Is this rhyming-slang?
Old   September 25, 2001, 07:57
stefan
You say that you use the cdsave command to get the model title. I assume that you open the generated .inp file and read the title from there. You could do something similar with a plot file or a postscript file generated out of it. Make a plot with at least the title and subtitle on it. As they are normally located at the same position, you can easily find out the location where the subtitle is generated in the plot or postscript file and then read it from there.
Old   September 25, 2001, 08:09
Joern Beilke
I already did it
Here is the perl script to extract title and subtitle from the plot file:
#!/usr/bin/perl
# (c) Joern Beilke , 2001
if (!defined $ARGV[0]) {
print "USAGE : subtitle.pl casename\n";
exit;
my $casename = $ARGV[0];
open(IN , "<${casename}.plot") || die "Datei '${casename}.plot' ist nicht vorhanden";
@alles = <IN>;
$text = join("",@alles);
$text =~ s/\n//g;
while ($text =~ /.*2,0.15,0.7,5,1,([\d]+),(.{120}).*/g) {
$i = $1;
$title = substr($2,0,$i);
print "TITLE: $title\n";
while ($text =~ /.*2,0.15,0.45,5,1,([\d]+),(.{120}).*/g) {
$i = $1;
print "SUBTITLE1: $title\n";
while ($text =~ /.*2,0.15,0.2,5,1,([\d]+),(.{120}).*/g) {
$i = $1;
print "SUBTITLE2: $title\n";
Old   October 8, 2001, 11:40
Joern Beilke
The line
@alles = ; must be changed to
@alles = <IN>;
The correct version was posted but one has to look at the html-source to get it. The "<IN>" was interpreted as a html-command.
Old   October 8, 2001, 12:17
Joern Beilke
Even when I put in the correct html command to create the "less than" sign, it does not work correctly.
So please look at the "page source" to get the correct version.
extracting the data usker Siemens 1 October 4, 2008 09:15
extracting output from the udf brusly FLUENT 0 April 25, 2008 01:10
Extracting Ux Uy and Uz from probed U retech OpenFOAM Running, Solving & CFD 1 January 7, 2008 09:31
Extracting data. Sham FLUENT 2 August 16, 2005 10:39
Extracting *.msh Y FLUENT 7 February 25, 2005 03:33
