Finite rate chemical reactions
Old   November 16, 2001, 18:25
Default Finite rate chemical reactions
Marc Segovia
Hello
I am new in CFD, and in a few weeks I would use STAR CD software, one of my main applications is chemical reactors simulations. Could someone give advice or references about finite rate chemical reactions. How CHEMKIN could help with this ? I would be grateful, thanks in advance by your help.
marc
Old   November 27, 2001, 04:16
Default Re: Finite rate chemical reactions
Daniel
It depends if your reactor is chemistry or turbulence controlled - in the latter case you should use the PPDF or Eddy-Breakup combustion models that come with prostar. The former case, however, is more complicated, since prostar allows only for 6 irreversible reactions. If you need more, you have to write your own user subroutines which complicate matters in many respects.
regards, Daniel
Old   November 27, 2001, 16:52
Marc Segovia
Thank you , Daniel by your answer. Initially I am thinking chemical controlled reactions, do you have some experience in this case (using user routines). Do you know if ChemKin made this approach easy ? Best Regards. Marc
Old   November 28, 2001, 04:21
Daniel
Yes, I am using user routines (see my posted question above) with some difficulties. I know Adapco and Reaction Design (the developers of chemkin) are working on an easy interface between the two, and even saw an article that used the beta version of this software, which, unfortunately I have not seen myself. However, since the user routines are written in FORTRAN, it should be possible to call chemkin subroutines there if you have the open code of the latter.
Chemical reactions in STAR CCM+ AS Krishna Reddy Siemens 0 January 2, 2009 01:28
How to define chemical reactions fred OpenFOAM Running, Solving & CFD 0 April 13, 2006 05:15
How to specify chemical reactions in certain areas Esti Siemens 0 September 24, 2004 06:03
Chemical Reactions Kavita CFX 4 September 12, 2004 21:22
Chemical Reactions with Shocks Arun FLUENT 0 May 20, 2004 17:24
