Problem in TE model and cell size
Old   December 11, 2001, 07:36
Default Problem in TE model and cell size
Mir
When we start a new calculation after a few iterations it explodes. The file info sometimes writes "Warning negative energy dissipation" other times writes "inflow detected at outflow boundaries". We can 't understand where the problem could be. We think that God hate all the people who want to take the degree in this millennium!!! Seriously we think it could depend on scale factor of the model. Somebody of you has an idea to resolve our problem? And & Mir
Old   December 11, 2001, 08:57
Default Re: Problem in TE model and cell size
jamie
Not sure about the negative energy problem. For inflow detected at outflow boundaries, it means that you have a boundary defined as an outlet, but fluid is coming back in. Outlet boundaries don't like inflow. Either change to a pressure boundary (which is happy with inflow or outflow) or extend your outlet farther downstream.
Old   December 11, 2001, 09:46
daniel
The warnings you get in the info file could just be temporary calculation problems. Kind of hard to answer when you don't say what your physical problem is. Maybe you should try to reduce some relaxation factors.
Limit on maximum cell size to minimum cell size ratio albcem OpenFOAM Running, Solving & CFD 2 October 17, 2011 12:00
small size cell problem(moving mesh) Elyor Siemens 1 May 12, 2007 23:45
size of first cell near wall for k-epselon model mukkarum FLUENT 3 May 11, 2004 04:10
cell size solomon Main CFD Forum 0 May 17, 2003 13:52
Cell size Julie Polyakh Siemens 8 March 22, 2002 11:43
