negative densities
Old   January 11, 2002, 10:53
Default negative densities
Sabatini
hay People
how i can ileminate the negative densities in my model thanks
Old   January 11, 2002, 16:11
Default Re: negative densities
James
1. lower under-relaxation factor for pressure and/or velocity
2. enhance the number of sweeps
3. Have a look at the answers posted here in former times
Old   January 14, 2002, 22:42
ckuo
If this came with unreasonable high velocity and at very beginning of iteration, you may never get rid of it with your target flow rate. Maybe, one way to get around it (I assume your mesh is OK) is to reduce your start-up flow rate to lower initial velocity. Once flow pattern developped to reasonable and stable, ram up flow rate to approach targe B.C.
Old   January 15, 2002, 20:43
star-user
Perhaps just keeping the density constant for a few 100 iterations may help.
Old   January 31, 2002, 08:06
stephen
Make sure you are using a bounded differencing scheme such as UD or MARS. In fact don't ever use a differencing scheme that isn't UD or MARS (and only use UD as a last resort)
Stephen
negative densities john Siemens 0 March 19, 2008 06:32
negative densities Riyaz Ahamed Siemens 2 August 14, 2007 01:47
Negative Densities Chris Siemens 4 June 25, 2007 08:39
negative densities CMB Siemens 4 January 4, 2004 02:41
negative densities. Mihir Siemens 4 December 9, 2002 21:04
