QSOR together with radiation
Old   April 2, 2002, 03:03
Default QSOR together with radiation
Ossi
I have simulated engine combustion and the heat from combustion is in variable QSOR (in the info file). Now, I am also icluding radiation modeling and that seems to change QSOR also ? I though that QSOR is strictly the heat from combustion but it seems that something else is also added to it when radiation is included ? Does anybody know how does radiation affect the computation of QSOR ?
Old   April 2, 2002, 05:39
Default Re: QSOR together with radiation
daniel
It depends on your definition of QSOR, but if your'e using the subroutine from Adapco - this calculates the heat release a-posteriori, rather than the chemical heat of combustion, and includes radiation or any other heat source.
Old   April 2, 2002, 05:54
Ossi
I use my own coding for the combustion model (reacfn.f, an Eddy Break Up-type of a model). I also use the static, thermal enthalpy option. I wonder if it is somehow possible to extract the radiation part of the source term out from the QSOR ?
Old   April 2, 2002, 06:11
daniel
I did not quite understand where you define what QSOR is - is it in posdat.f? Anyway, if you calculate ther reaction rate in reacfn.f, why not just use the value you calculate there for the chemical rate?
Old   April 2, 2002, 06:18
Ossi
I do not define QSOR anywhere. STAR does that. And the problem with taking the heat out from the reacfn.f routine is that it is iterated, i.e. called many times during a time step. But indeed, maybe I can use posdat.f to extract the heat of combustion out (?) Let's see...
Old   April 2, 2002, 06:42
daniel
Why don't you extract the heat release just in the first iteration in every time step? reacfn.f receives the iteration number - use the ITER variable.
Old   April 2, 2002, 06:51
Ossi
Right, I could do that. (In principle, however, the first iteration result could still change quite a lot during the iteration process.) I will think about it.
Old   April 2, 2002, 07:55
daniel
another suggestion - define a "COMMON" variable in reacfn.f that would update after each iteration, and read it in the beginning of the next time step. good luck.
radiation temperature ,G(the incident radiation) ymg FLUENT 0 October 16, 2008 08:57
radiation brusly FLUENT 2 October 8, 2006 02:59
Radiation in CFX 5 Roued CFX 1 January 8, 2002 12:09
CFX Radiation Andrew Sleigh CFX 0 January 29, 2001 06:27
radiation john FLUENT 4 October 4, 2000 16:02
