Tutorial
Hi, I'm beginner user of Star-CD. I modeled the Tutorial 7.3 but I didn't undestand the procedure for run this analysis. The commands pmovlink and starlink didn't run. Please, what procedure should be executed for this analysis? Thanks
Re: Tutorial
pmovlink is used for an analysis using moving mesh events. You need to use pmovlink for this tutorial. Did you get some kind of error message?
Re: Tutorial
I don't know where I should type the pmovlink command: in the prostar prompt, in DOS prompt or other place. In prostar prompt this command return:"**UNRECOGNIZED COMMAND - (PMOV)ENTER A COMMAND OR HELP OR EXIT" In DOS prompt this command wasn't found.
Re: Tutorial
The tutorials are taylored to be used in Unix or Linux. For these OS, you need to type the command in the unix/linux prompt. For Windows, you need to go to Solve option on your Star-CD launcher and click on Moving grid case option. HV |
