next red hat problem
Old   May 24, 2002, 10:00
Default next red hat problem
Joel
OK so i solved my first problem now i have another, everything is installed and working fine, to a point when i run starlink i get the following message once it starts to compile and everything: Linking single precision sequential executable "rotate"...
f77: unrecognized option `-N3' f77: unrecognized option `-N26' f77: unrecognized option `-N15' f771: Unrecognized option `-f' ######################################
WARNING: Command execution error. Please check screen output for details
starin.f compile error.
Exiting starlink.
as far as i can tell absoft seems to be working fine and so does everything else, my environmentals seem ok too at least i cant see any problems with them. any ideas? cheers joel
Old   May 24, 2002, 10:35
Default Re: next red hat problem
Joern Beilke
ABSOFT=/usr/absoft ; export ABSOFT
PATH=:$ABSOFT/bin:$PATH:.
It is important that $Absoft comes before $PATH, otherwise try "which f77" and you see that the gnucompiler is used.
Old   May 24, 2002, 10:59
Joel
cheers you've made my weekend!
Old   May 27, 2002, 21:55
cjtune
Hmmm, these were exactly the same kind of problems I faced when I first installed STAR-CD on Red Hat. I renamed the original f77 compiler and in its place I created a symbolic link to Absoft's F90 instead.
Q: Could you get STARWATCH and starwdaemon to work properly?
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 05:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 07:45
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
