g77
Old   September 16, 2002, 05:43
Default g77
chneg
Does it possible that using linux's g77 instead of commercial Absoft Fortran. I used the -F parameter to pass the complier, but get some "library miss" message when "ld"...
thx!
Old   September 17, 2002, 06:40
Default Re: g77
James
No, it is not possible because the Fortran libaries from Absoft are required.
Old   September 17, 2002, 11:55
Default Re: g77
Steve
Given those libraries, it is technically feasible to link it all together (I managed it once). But I wouldn't recommend it as a working practice.
As an aside, I'm always a bit narked when expensive software requires you go out and buy more 3rd party software before you can use it. I think if StarCD requires Absoft FORTRAN, then CD-Adapco should drop the price accordingly or bundle the compiler.
