problem in reading ansys file
Old   November 26, 2002, 04:23
Default problem in reading ansys file
satya bulusu
I have created file.elem and file.node file from ansys pre-processor. I tried to read these two files in STAR-CD using import grids with ansys option
ansy,file.elem,file.node
I got following error message.
READING ANSYS ELEMENTS FROM file.elem READING ANSYS NODES FROM file.node
ERROR ELEMENT 1 HAS AN IMPROPER NUMBER OF NODES
(DOES NOT MATCH EXISTING DEFINITION IN CTABLE)
1 ELEMENT READ. MAX ELEMENT IS 0 6265 NODES READ. MAX NODE IS 6265
element 1 has following list from ansys
1 72 73 3 0 0 0 0 1 1 1 1 0 1
Can you help me why i am getting such an error.
Old   November 26, 2002, 06:33
Default Re: problem in reading ansys file
Andreas
I guess, you have to define the proper cell type in StarCD before importing the grid. The element looks like a shell with cell type 1. So the cell type 1 in StarCD should also be of type shell.
Hope that helps
Cheers, Andreas
Old   November 26, 2002, 09:32
satya bulusu
thank you andreas, this has helped me to import.
one more question, does STAR CD retain the material type, element type of ANSYS in STAR-CD so that it will be easy for me to defien material properties and boundary conditions.
Old   November 27, 2002, 03:29
Andreas
As far as I know, the interface can only handle grids (cells and vertices). You have to redefine your properties and boundaries. I'm not sure if you could save the ansys properties as a coded file and import it into Star. I never tried it. I just use the interface to pass along the grid between Ansys and Star.
problem with reading my prePDF file into fluent James Willie FLUENT 9 March 10, 2012 02:51
Reading ANSYS mesh into my own code Soheyl CFX 1 June 18, 2007 18:51
Reading ANSYS mesh into my own code Soheyl Main CFD Forum 0 June 18, 2007 15:30
problem with reading the .dat file,error object:#f Paulina FLUENT 6 November 7, 2006 15:49
ANSYS ICEM CFD: lsdyna input file creation problem Evan CFX 0 June 15, 2006 13:12
