How to fix a node on intermediate spline's vertex
Old   December 10, 2002, 04:02
Default How to fix a node on intermediate spline's vertex
Fuligno Luca
Someone knows if it's possible to fix a node on a intermediate vertex of a spline? In this way I can create, for example, 2 different blocks connected with only 1 contiguous block with matching meshes without using "cpmatch" (I've a very big and complex mesh, and cpmach seems to be very slow). I've tried with "blktrace", but this command seems to modify separately each one block of the selected blockset, so I've to produce on the biggest block a mesh fitted on the coarsest mesh of the small lateral blocks. Thank you! Luca
Getting intermediate values for pUT etc srinath OpenFOAM Running, Solving & CFD 2 July 7, 2008 22:13
how can i list node temperatur by node location Ali Doustdar FLUENT 2 July 12, 2007 23:48
turbulent quantity goes -ve for intermediate run Sourabh Main CFD Forum 0 November 28, 2006 23:37
Intermediate Restart Files RK CFX 0 September 6, 2005 09:32
CFX 5.5.1 and writing intermediate results Andrej CFX 1 January 18, 2003 21:00
