March 4, 2003, 07:16 |
high-Re-turbulence-model
does anyone know what happens when I use the high-Re turbulence model and my y+-values are below 30 in some areas ? Is it essential to change the mesh accordingly or are the wall functions simply applied up to y+ = 30 ? Thanks in advance, Stefan |
March 5, 2003, 05:23 |
Re: high-Re-turbulence-model
Hey Stefan!
The wall functions are applied to any wall cell. Depending on your y+ value the viscous sublayer is assumed too thin (y+ < 5) or too thick (y+ > 30), what has effect on the gradients normal to the wall. Geetings Marc |
March 25, 2003, 03:40 |
Hallo Stefan
In the case of wall shear stress the wall shear stress calculated in a straight pipe is almost constant for y+ values between 20 and 200. Below 20 the wall shear stress increases dramatical. Regards Bo |
High speed multi-phase flow turbulence | Purkmeisster | Main CFD Forum | 0 | December 18, 2006 06:58 |
High Combustion Temperature in the EBU model | Mehdi | Siemens | 0 | April 24, 2006 05:53 |
High Reynolds Number Model | Elaprolu Vishnuvardhnarao | Main CFD Forum | 0 | July 11, 2005 07:11 |
high RE Turbulent model | autofly | Main CFD Forum | 1 | July 1, 2003 11:45 |
