Clclic boundary application
Old   June 17, 2003, 03:53
Default Clclic boundary application
Nandu
I am having a problem with the application of cyclic boundaries in the CD model. Is it a rewuirement that the model is created such that the axis of symmstry (for a wedge shaped model) must lie on the the y axis?
cheers Nandu
Old   June 17, 2003, 03:59
Default Re: Clclic boundary application
Vlad S
The answer for your question is given in Tutotial>Pro-Star tutorials>Tutotial 9. You should apply the cyclic boundary condition, then couple them together. It should works but on my computer it doesn't (( It writes me about a couple errors in coupling. Try to complete this tut. Good luck Vlad S
Old   June 17, 2003, 07:48
4xF
Please also check that the coordinate system you use in the boundary definition of the cyclic boundary is the one you want to use for coupling. Do not make the mistake to leave the definition of the coordinate system to 1 if you use the coordinate system 2 to define the cylindrical mesh.
Old   June 24, 2003, 20:14
skipio
y+ application vivek.k.yakkundi FLUENT 2 October 22, 2007 12:17
application of CFD REKHA FLUENT 1 January 13, 2005 01:25
application of cfd samuel R devadoss Main CFD Forum 0 March 15, 2004 04:38
PER & MIR application dimitris Main CFD Forum 1 January 14, 2001 05:10
bio-application Jean-Yves Main CFD Forum 3 February 16, 1999 13:28
