Export locally refine meshes to Tecplot
Old   June 17, 2003, 07:44
Default Export locally refine meshes to Tecplot
Jens
Hi
Does anyone have a macro that can export locally refine meshes from prostar to Tecplot ?
If so, please reply.
Thanks
Jens
Old   June 18, 2003, 11:24
Default Re: Export locally refine meshes to Tecplot
steve
Why do you need a macro? prostar can export any mesh directly to tecplot with a few button clicks.
Old   June 18, 2003, 15:44
Jens
Hi
Tecplot will not import a mesh with local mesh refinement. Something about the cell couples. The same thing as with Fieldview. It does not import cell couples.
Therefore I am look for another way.
Any suggestion ?
Regards
jens
Old   June 18, 2003, 18:02
steve
The problem is that tecplot does not have any concept corresponding to a couple (ie something that joins meshes that are not topologically perfectly connected). There is nothing that you can do in prostar to make up for that deficiency in tecplot other than remodel your refinements with some combination of tets and prisms in the transition area. I suppose what you are asking for is if anyone has an automated refinement macro that does not rely on cpmatches? I'm sorry - I don't have one but I have seen them. Maybe someone else out there does.
Regards, steve
TECPLOT EXPORT tasos Tecplot 2 June 26, 2007 01:50
how to export the cfx result to the tecplot dpshaka CFX 0 December 1, 2005 11:00
export CFX results to Tecplot Cui CFX 6 January 27, 2004 02:55
export from fidap to tecplot pradeep sivakumar FLUENT 0 August 28, 2001 19:34
export results to Tecplot? Jeff FLUENT 6 July 18, 2001 22:10
