Problems saving graph registers data
Old   July 23, 2003, 04:50
Default Problems saving graph registers data
Julie Polyakh
Prostar doesn't save graph registers data. It just creates an empty file case.grf.
Old   July 23, 2003, 09:44
Default Re: Problems saving graph registers data
Timo Kurz
Hi Julie!
You just have to save it two times, then it should work. I think itīs a bug in the program.
mfg Timo
Old   July 23, 2003, 09:55
Julie Polyakh
Hi Timo,
Thanks for your advise, but it doesn't work...
Old   July 23, 2003, 12:36
cjtune
You need to CLOSE the file first, otherwise ProSTAR will just keep it in memory until you exit (at which point the .grf file will be also fully written down to disk).
eg. CLOS "XYX.GRF"
Old   August 6, 2003, 13:32
Micha
I think it is important to give exactly the right number of registers to be saved. If you have 4 registers with data you want to save, saving doesn't work when you write 5 in the box for "number of registers" to be saved. I had the same problem and this was the solution for it in my case.
How to read the data from the graph Kottam Main CFD Forum 2 June 14, 2008 16:46
saving data mange FLUENT 3 October 14, 2004 18:40
Automatically saving a line graph Astrid CFX 1 April 28, 2003 06:48
Saving graph register data into a file Julie Polyakh Siemens 1 January 27, 2003 21:35
Post-process: how to extract Graph Registers' data Jiaying Xu Siemens 11 July 17, 2002 04:38
