Grid dependence check
Old   July 28, 2003, 05:10
Default Grid dependence check
Julie Polyakh
What difference between results obtained with different meshes is acceptable to say that no additional refinement is needed?
Old   July 28, 2003, 14:02
Default Re: Grid dependence check
allan
I would say 5%, but it can depend on a lot of issues!!
Have you got the Ercoftac domumentation yet? It gives guidelines to a lot of these basic questions you're asking
allan
Old   July 28, 2003, 14:23
Julie Polyakh
Hi Allan,
No, don't have the Ercoftac documentation. How can I get it?
Thanks for your response,
Julie
Old   July 28, 2003, 15:35
4xF
Have you ever heard of Richardson extrapolation? This gives you as well a mean to check for the mesh independent solution. See also Ferziger & Peric, Computational Methods for Fluid Dynamics, Springer, 2001
Old   July 29, 2003, 04:24
Julie Polyakh
How exactly do I perform the check for independent solution using Richardson extrapolation (for example, applying the material given here: http://www.math.ubc.ca/~burggraf/math256/richardson.pdf)?
Old   July 29, 2003, 05:26
allan
go to their website:
http://www.ercoftac.org
click on the link ercoftac publications then best practice guidelines
allan
Grid check failed Norasikin Mat Isa FLUENT 2 August 31, 2011 03:30
grid check in FLUENT wan aizon FLUENT 4 January 20, 2006 04:33
help! grid check error Gary Holland FLUENT 9 April 25, 2005 13:37
Grid Check problems Ben Siemens 2 June 24, 2004 21:49
Grid dependence check Julie Polyakh Siemens 1 July 19, 2003 17:23
