Challenge of differencing scheme choice
Old   July 28, 2003, 05:01
Default Challenge of differencing scheme choice
Julie Polyakh
Calculation with UD differencing scheme yields results that are closer to the experimentally measured velocity profile. However, with MARS scheme the curve behavior is very similar to the one of experimental data. Which scheme would you choose?
Old   July 28, 2003, 08:38
Default Re: Challenge of differencing scheme choice
Ossi
Basically, one should not use UD for computations. However, sometimes it is the only choice due to bad convergence. But generally speaking, stick to MARS or other second order scheme !
Old   July 30, 2003, 11:12
cjtune
If your flow doesn't have sharp gradients or the only mesh you can afford is a coarse one, then it's UD. If you wish to dampen out oscillating effects (ie. simulate a transient phenomena as steady state to just get 'bulk' values -with 2nd orders will not converge), then that's another reason to use UD. But don't expect anything other than 'in-the-ballpark' figures for your results.
Differencing Scheme MARS michael OpenFOAM Running, Solving & CFD 1 August 10, 2006 10:51
differencing scheme....help P.kalyanakumar Siemens 1 July 27, 2005 22:54
MARS differencing scheme Bart Siemens 4 January 27, 2005 09:43
Central differencing scheme alice FLUENT 1 March 11, 2004 19:07
Differencing scheme for k-eps model Ron Barer Main CFD Forum 14 November 2, 2000 00:02
