Lagrangian multiphase switch
Old   October 10, 2003, 05:58
Default Lagrangian multiphase switch
Alfred Herman
Iam simulating a diesel engine with transient mesh. To simulate fuel injection, I had switched on the Lagrangian multiphase switch and given the relevant droplet properties through automatic initialisation (spray modelling) panel. But when the solving is initiated, I get the following message:Bus error <coredump>. On switching off the switch and solving, I do not get the error message. I need a clarification on this.
Old   October 14, 2003, 07:28
Default Re: Lagrangian multiphase switch
carno
Hi, If you have multiple CPU machine, try to solve the same problem with STAR HPC. I faced similar problem while solving big mesh problem involving aeroacoustic analysis. After splliting the problem it worked fine. Better get clarification from support. In my tasclist also this clarification from support is pending....
Thanks
lagrangian multiphase analysis Marco Siemens 3 September 22, 2008 09:43
lagrangian multiphase analysis bala Siemens 3 April 28, 2008 02:13
lagrangian multiphase analysis bala Siemens 2 April 24, 2008 07:52
lagrangian multiphase analysis bala Siemens 0 April 15, 2008 01:35
analysis restart for lagrangian multiphase mic Siemens 0 July 5, 2007 08:36
