large executables-mandrake 9.1
Old   October 23, 2003, 04:08
Default large executables-mandrake 9.1
allan
Hi
I'm have 1.5GB of ram and I'm having a bit of a problem with executables greater than about 700MB, they don't run. I either get a segmentation fault or if I starlink -Y then the executable is not created I get the error message /usr/bin/ld: cannot find -lc. I'm using Absoft v7.5 compiler with both patches. Has anyone any experience of this?
Thanks
Allan
Old   October 26, 2003, 05:51
Default Re: large executables-mandrake 9.1
4xF
Obviously, the libc is not found. Either it is not installed or the linker cannot find it beacuse the path ld is looking to for finding the libraries is wrong. Please check both.
Old   October 26, 2003, 11:41
allan
Hi
Thanks for the reply.
I got fed up with mandrake and other problems I've had with large exe's and sementation faults, so I installed SuSE, which CD recommend, and everything works fine now.
Allan
Parallel Fluent with Mandrake Daniel Dotta FLUENT 1 May 19, 2005 15:30
Linux Mandrake v9.1 allan Siemens 2 October 6, 2003 14:56
CFX 5.6 on Mandrake 9.1 -success matej forman CFX 1 August 15, 2003 19:40
softwares required to build local executables Danie CFX 9 June 11, 2003 03:51
Need liscense to run star executables? Jiaying Xu Siemens 4 September 21, 2001 08:14
