Generating table values in a loop
Old   November 26, 2003, 01:58
Default Generating table values in a loop
Jarrod Sinclair
I am trying to append to a table within a "*define,execute" loop and am having problems. The resulting values are always zero. When I do not use the loop and enter the values manually, it works fine. Is this a limitation in Pro-Star?
I am using the following pro-star code:
*set,tim,dt,dt
*define,execute
*set,vel,tim * 0.1
*scopy,vel,svel
tbmodify,add,time,tim
{svel}
*end
*loop,1,10,1
Thanks.
Old   November 26, 2003, 19:26
Default about natural convection
Juliet
hello,everybody
i am solving a problem involved the natural convection and eletro-chemical reaction, i make the sorsca.f,sorent.f,and fluinj.f for some layer, also the density is set to idea f(t) or isobaric. and Gy=9.81, PISO algorithm,steady state. in addition, i add about same length ambient air mesh as actual model. but when calluate it, always divergence and unstable, and enthalpy residuel is INF,or very large. why? i would appreciate if you can give me some explain or advice. if you anybody once have done some work like this or have some example about this, whoud you please sent me that? by the way, for natural convection, how much additional mesh should be? thanks a lot
Juliet
Ensight - node values -cell values leo FLUENT 1 May 12, 2010 08:47
loop(p,I->p) how this loop works? Sinan FLUENT 0 January 18, 2005 18:04
Generating mesh Jonathan CFX 2 February 13, 2004 00:27
Generating Mesh (CFX) Steven CFX 1 February 25, 2003 11:53
Generating Mesh Steven CFX 0 February 25, 2003 11:31
