Problems with Merge
Old   February 17, 2004, 08:04
Default Problems with Merge
Sabe
hi,
There is something curious going on when I merge vertices that do belong to a spherical shape!? The merging operation is successful but the cells can't be seen or selected anymore(there are still in cell set). The merging operation deletes way more then the model would need, only the half of the needed points remain! How come? I tried: -small sets of points, did not work out -i build a cylindrical model, that has the same number of vertices to merge and it works. so I assume it has something to with the spherical shape... Any advice is welcome,thanks in advance. Greatings Sabe
Old   February 17, 2004, 13:50
Default Re: Problems with Merge
Brian
Polar meshes (those created in cylindrical or sperical coordinate systems) tend to concentrate a lot of cells (and vertices) at the centre of the circle. These cells usually end up as prism cells (or perhaps pyramids in a sperical system). As the number of cells in the centre is the same as on the circumference in the tangential direction, these cells can get very small, and the vertices that define them are therefore very close together.
VMERGE has an input variable, "tolerance". This value, by default 0.1mm, can easily be bigger than the distance between adjacent vertices in meshes created in this way.
This long story simply serves to tell you that you need to reduce the tolerance in the VMERGE command.
merge zones Domi FLUENT 2 May 3, 2019 13:15
Grid Merge boris FLUENT 8 July 27, 2011 07:58
[Technical] Merge patch erydj OpenFOAM Meshing & Mesh Conversion 0 July 21, 2008 20:40
Fuse or merge Ligr FLUENT 1 June 24, 2006 23:47
Help!! Is it possible to merge two cas-files? Thomas FLUENT 6 March 21, 2005 08:06
