February 13, 2004, 05:34 |
parameter NCMAXV OR NBMAXV
after running a computation with heat transfer with constant molecular properties, I want to switch to user coded properties. When I try to restart now, the message is: *** ERROR #210 *** INSUFFICIENT DIMENSIONS FOR THE MOLECULAR VISCOSITY ARRAY.INCREASE PARAMETER NCMAXV OR NBMAXV AND RECOMPILE. Using the command MEMORY shows, that there are no such parameters. Any hints are welcome - Frederik! |
February 13, 2004, 05:45 |
Re: parameter NCMAXV OR NBMAXV
So I found that the parameters are listed in the parm.inc file. After changing it successively to a number that is far above the number of my model's cells, the error still prevails. Still, any hints welcome ...
February 13, 2004, 08:28 |
You should re-write your geometry and problem files. If there is now a file called parm.inc.new, move it to parm.inc. Then do starlink again (on UNIX) or just rerun STAR (on Windows).
February 16, 2004, 07:52 |
Thank you for your answer, I tried your suggestion. There was no parm.inc.new file written. By the way, everything works if cp (SPECHT.F) is user coded, but fails with conductivity (CONDUC.F) and viscosity (VISMOL.F). I also manually changed the values for N(C/B)MAXV in parm.inc to something 10times the number of my cells. This doesn't work either. Is there any documentation on such issues (parameters and sizing) availlable?
February 16, 2004, 09:48 |
You shouldn't have to edit the parm.inc file by hand, so there's no documentation on these parameters. They should be invisible to you. If you have tried what I suggested in my last posting and it does not work, you've probably found a bug. Contact STAR support.
February 16, 2004, 10:44 |
If version 3.2 ever gets released, these problems should be a thing of the past.
February 17, 2004, 23:42 |
February 21, 2004, 06:32 |
Edit your parm.inc file to set NCMAXV=NCMAX and NBMAXV=NBMAX. If your heat conductivity option is not selected as constant, you may need to set NCTMXC=NCTMAX ans NBTMXC=NBMAX as well.
Good luck ! |
February 23, 2004, 09:28 |
I did all of this, it doesn't work I have the impression that the error message itself is misleading.
two parameter on the same plot | ammi reddy | FLUENT | 0 | March 22, 2007 23:47 |
Kinetik parameter for CO + 0.5 02 -> CO2 | Martin | CFX | 0 | January 26, 2006 09:30 |
using parameter with gambit | tone | FLUENT | 0 | October 3, 2005 10:41 |
NFMAX parameter | Sileno | Phoenics | 2 | January 12, 2005 05:42 |
Penalty Parameter | Kai Kang | Main CFD Forum | 1 | March 13, 2001 04:38 |
