radiation problem
Old   May 10, 2004, 03:23
Default radiation problem
F.K.
I' dealing with a complex radiation problem and all checks within prostar are ok, but the compilation fails with the message "error on line 1530 of starin.f: program has invalid use of COMMON name"
Any suggestions what could be wrong???
Thx
Old   May 10, 2004, 07:58
Default Re: radiation problem
Richard
Are you running on a 32-bit OS, such as PC Linux? The problem may be that your executable is (or rather would be) too big for the OS. The memory requirement for radiation can be very high as it scales with the (number of patches)**2. If this is the problem, the workaround would be either to change to a machine with a 64-bit OS, or to reduce the number of patches.
Old   May 10, 2004, 10:37
F.K.
Thank you for your help. I have reduced the number of patches and now it works.
Radiation problem Rahul Hiwale FLUENT 7 July 30, 2022 03:48
radiation problem lavendar Siemens 0 June 8, 2005 22:19
solar radiation problem Cha Siemens 0 June 13, 2004 16:11
Radiation problem Giovanni FLUENT 0 May 13, 2003 02:32
Radiation problem Giovanni FLUENT 0 May 7, 2003 07:55
