extruding patches
Old   June 21, 2004, 13:30
Default extruding patches
Ben
Whenever I create a patch, it consists of 2-D shells. After I extrude the patch, the shells are still there. How do I get rid of the shells?
Also, can anyone offer any insight on vcextrude command? Can I extrude to a certain length with a desired number of cells along that length?
Cheers,
Ben
Old   June 21, 2004, 22:11
Default Re: extruding patches
CFD expert
You are using star-cd for meshing? No wonder you cannot extrude your patch... Try ICEM CFD!
Old   June 21, 2004, 22:26
Ben
Old   June 21, 2004, 22:28
Ben
Star CD is all I have access to. My choices for mesh building are Pro-Star or Pro-am, which seem very similar to me.
Can anyone help?
Thanks
Old   June 22, 2004, 02:58
vladimir
hi ben
patch command deals with shells only it creates a new shell within a four vertices you pass to it
vcextrude command is meant to extrude cells using the active cell type for the new cell layers thus if your active cell type is shell you will always generate new shells instead of fluid cells
if you do not know how the command works try to F1 key or type help command (help vcex in your case) when in prostar or read the manual pages in $STARDIR/man/commands/star_commands.pdf (depends on star version) for further reference on command use there are even tutorials provided by adapco in the following directory $STARDIR/man/tutorial/
Old   June 22, 2004, 21:36
steve
First there is no need to delete the shells. They are ignored by the flow solver. However, if you want to get rid of them type
cset news shell
cdel cset
The vcextrude does just what you want. Type HELP,VCEX and look at the parameters. Its really not very hard
Old   June 22, 2004, 23:07
Ben
Okay, so I got how to extrude.
But I need to build a pipe, a regular round pipe with fluid flowing through the middle. When I use cylindrical coordinates, it has problems at the center where the cells come together. It was suggested to me to make a pipe without the center ( if that makes sense ) and then extrude something through the middle of it. This causes a lot of problems that I don't know how to fix either.
Anyone know how to do this, or a better to accomplish what I am trying to do?
Thanks
Old   June 23, 2004, 02:56
Jörn Beilke
Do a search for "butterfly" in this forum and you will find what you need.
Save those examples in files and open them in the prostar editor. From there you can execute them.
[blockMesh] StitchMesh on two patches anita OpenFOAM Meshing & Mesh Conversion 31 April 4, 2013 11:51
[Gmsh] How to define these patches zhoubinwx OpenFOAM Meshing & Mesh Conversion 6 September 15, 2008 08:52
error in polyflow while inverse extruding shyam chunduru FLUENT 0 July 14, 2008 23:01
rediation patches novice Siemens 2 February 25, 2004 03:53
extruding holes Dixy Phoenics 0 November 13, 2003 11:17
