June 23, 2004, 15:06 |
Streamline calculation using droplets...
Hi All,
I am trying to calculate the length of streamlines in a flow field where there is significant defelction due to separation. I am using droplet and have written a code to calculate the distance travelled by the droplet at different cells using subroutine dropro. My problem now is I dont know what properties I should be using for the droplets so that it followes the flow path of the gas. Any help will be greatly appreciated. Best regards StarCD |
June 24, 2004, 06:47 |
Re: Streamline calculation using droplets...
Be very carefull when calculating streamlines, because it is easy to make a confusion between streamlines and pathlines of particles. Streamlines are the same under the following assumptions: 1) particles are massless 2) flow is steady
If you cannot satisfy 1 & 2, then you will calculate pathlines which can be very different from the flow streamlines. |
June 27, 2004, 14:32 |
Hi 4xF,
thanks for your response. I know what you mean and no I cannot satidfy the above conditions. However, I am indeed in luck as a paper by Y.B. Suzen gives a nice transport equation for streamlines which can ezsily be calculated as a scalar in STAR-CD Cheers StarCD |
plot streamline | taw | Main CFD Forum | 6 | August 16, 2009 12:26 |
2D streamline | Junseok Kim | Main CFD Forum | 4 | August 13, 2006 03:37 |
streamline | ahad | Phoenics | 1 | April 15, 2003 15:58 |
about streamline | caowei | Main CFD Forum | 4 | January 27, 2002 19:32 |
how to get streamline | jeff | Main CFD Forum | 4 | May 9, 2001 13:47 |
