Shell
Old   July 2, 2004, 10:57
Default Shell
Aline
I have done a patch and then I have extruded it. But now I want to define the boundaries, and I can not define any on the shell from the initial patch. What can I do?
Thanks.
Old   July 2, 2004, 11:43
Default Re: Shell
StarCD
How did you extrude it?
As far as I know, shell type cell is used to define the patches, which are then converted to fluid or solid or whatever you need before any boundaries can be applied.
If you have 2D model, one way to extrude your geometry is to use 2D3D cartesian x... where x is the amount of extrusion.
This results in symmetry planes being automatically applied to the extrusion plane. Then you can aplly other boundaries wherever u like.
Hope this helps
StarCD
Old   July 2, 2004, 11:56
Default Re: Shell
Aline
I have finally defined the boundaries, but the patch seems to create a discontinuity in the fluid cells. But perhaps it is normal. I will see if the resuls are coherent.
Thanks!
Aline
Old   July 2, 2004, 11:59
Default Re: Shell
StarCD
Check cell aspect ratio and tolerance when you merge the vertices
Old   July 2, 2004, 12:23
Default Re: Shell
Panos
Be also careful when you click on the cells for boundaries not to click twice because you will get errors in boundaries. For example if you have a symmetrical 3d model and inlet and oulet boundaries must be equal. Otherwise you will get the message "boundaries in the exterior not found". Before you apply the boundaries you have to change cell type to fluid type (1) in the STAR Guide.
Old   July 2, 2004, 13:39
Default Re: Shell
4xF
A usefull command to create boundaries from defined shells is BSHELL (see also the online help for the use of this command).
Old   July 7, 2004, 02:30
Default Re: Shell
Matej
Aline,
Forget what Panos says. It is completelly nonsense. (sorry to say so).
If you have discontinuity in the mesh, it is not because of shell cells. It is because your cells has separate vertices (points in cell corners) defined on the same place. What you have to do is to merge those vertices. Look in manuals for merging vertices.
matej
CCM+ & ssh shell on IBM Petr Siemens 0 December 5, 2008 03:29
Shell Conduction Corentin FLUENT 1 November 12, 2008 05:54
FSI- shell Federica Main CFD Forum 0 February 28, 2007 18:50
Shell conduction with VOF ??? Asghari FLUENT 0 May 31, 2006 11:38
Shell modelling Srini Main CFD Forum 0 April 14, 2005 00:16
