gas properties
Old   July 6, 2004, 05:44
Default gas properties
Riccardo
Please help me! I'm not able to set the gas properties in StarCD; I found only cv but not cp or R (cp-cv) or Gamma (cp/cv) Thanks in advance for your reply
Old   July 6, 2004, 14:56
Default Re: gas properties
4xF
R is the gas constant, so this will not change. Actually, if the gas is incompressible (density is constant), Cv is used. If the gas is compressible, assuming the ideal gas law, you only need to define Cp. Cv and Gamma are then calculated internally (Cv=Cp-R and Gamma=Cp/(Cp-R)).
Hope this dissipates your doubts...
Urea properties Lokesh Siemens 7 April 15, 2017 04:28
properties Fei W CFX 3 November 26, 2008 02:52
Help::Air Properties ashish FLUENT 2 June 6, 2007 14:24
oil properties carno Siemens 0 March 23, 2004 00:22
Properties at X,Y,Z Raghav Sarma Siemens 2 April 11, 2003 03:02
