July 22, 2004, 05:11 |
creaction of a very small cylinder
when creating a relatively big (r=1, L=20) in folder creating 3d grids with simple meshes (using cylindrical coordinates), there is a sort of plane between the 0 and 360 degreees, if i merge them the cylinder is perfect. However, I want to make a (r=0.00002 and L=0.0008) cylinder and when I merge the cylinder it collapses.
How can i make a small cylinder without any errors? Thanks |
July 22, 2004, 07:05 |
Re: creaction of a very small cylinder
There is a value "tolerance", which must be set smaller than the grid spacing
July 23, 2004, 12:04 |
...And the other way is to use different units when creating the model, not meters, and then speciying the geometry scale factor
3-d mesh gambit (cylinder within a cylinder) | Jason | ANSYS Meshing & Geometry | 29 | October 30, 2015 08:59 |
small cylinder and big cylinder | Eric | CFX | 1 | January 26, 2007 05:38 |
Help meeee: Wave cylinder (sine cylinder) | Ngoctq | FLUENT | 0 | December 29, 2005 20:46 |
How Small is Zero ! | Ajay Rao | FLUENT | 2 | December 5, 2003 03:26 |
modeling of small size cylinder | Tim | Main CFD Forum | 5 | March 10, 2001 13:28 |
