URGENT: command to start STAR-CD 3.2
Old   July 30, 2004, 11:19
Default URGENT: command to start STAR-CD 3.2
sunlight007
hello, for the previous version starlink worked but is not accepted for STAR-CD 3.2 in the separate window (linux). Please help.
Old   July 30, 2004, 12:02
Default Re: URGENT: command to start STAR-CD 3.2
user
just type 'star'
use 'star --help' to see the various options/flags available
Old   July 30, 2004, 12:28
sunlight007
it does not work i tried till now starlink star -h star -help star --help
Old   July 30, 2004, 13:55
Jörn Beilke
for starting the solver just type "star" or use the "starlaunch"
Old   July 30, 2004, 14:08
sunlight007
i mean to start a calculation
Old   July 30, 2004, 15:54
Jörn Beilke
Thats what I mean. Just type star and the calculation should start.
Old   July 30, 2004, 17:24
sunlight007
i started it through navcenter and will try the STAR command tomórrow. Thanks Jörn
Old   August 2, 2004, 03:11
vladimir
... shalt thou type star. No more. No less. Star shalt be the word thou shalt type, and the word of the typing shall be star. Starlink -h shalt thou not type, nor either type thou starlink, excepting that thou then retype to star. Starlink is right out. Once the word star, being the right word, be reached ...
if this is not believed then appendix H of the star userguide is to be read.
vladimir
Old   August 2, 2004, 04:10
sunlight007
perhaps sir, you confuse sir, the heavenly stars with star-cd???
Old   August 3, 2004, 07:16
steve
did you do a
source "path to star"/etc/setstar
or equ in ksh
before you tried to run star?
you should see information about
STARDIR: STARINI: CDLMD_LICENSE_FILE: LM_LICENSE_FILE:
ABSOFT:
etc.....
Old   August 5, 2004, 07:52
  #11
Noé
You can try with : star --version 3.200
It should work (by me it works!)
start of star-cd balashowry Siemens 1 March 5, 2008 18:32
Problem to start pro-Star. Piyapong Siemens 5 January 3, 2006 13:22
I have problem to start star-cd. Piyapong Siemens 3 October 28, 2005 02:27
How to start with STAR-CMM+, please help Michail Kirichkov Siemens 2 September 6, 2005 21:12
How to start phoenics from command level? Peiyong Phoenics 0 May 8, 2005 23:10
