September 13, 2004, 10:01 |
Error attempting to open X display
Hi I Installed new version of star cd 3.22.001 for windows2000.But I am not able run the prostar.It is giving error as this Error attempting to open X display, without opening any window.Could you please help me in this regard. The dispalyed error is as fallows:
Feature starsuite expires in 260 days Error attempting to open X display Thanks&Regards Pradeep Pantangi |
September 13, 2004, 20:08 |
Re: Error attempting to open X display
1)Are you sure you are using WINDOWS version?
2)Check your setting for the visualisation. CFD |
September 14, 2004, 06:06 |
Hi I you are using Windows,Then Problem is due to Exceed. Check it up.
Thanks Dhandapani |
September 14, 2004, 08:00 |
If you are using Windoze, you'll be wasting your time in the long run, so I'll not offer any help.
If you are being sensible and using UNIX (incl. Linux), you've either got your DISPLAY set wrong (or not set at all) or your X terminal isn't accepting remote connections. If you are sitting at the machine: arse, then do the following: 1) In your STAR window, type: setenv DISPLAY arse:0 2) Open a local window on arse and type: xhost + |
September 14, 2004, 14:19 |
A question for you...
are you using the provided SCO XVision? if you are, is you machine using an Intel graphics card? There is compatibility issue between XVision and certain intel graphics cards. |
September 14, 2004, 14:25 |
Hi kevin,
It is the problem with SCO XVision.Just I ran Xvision ones, then everything is ok!Now it is running.Any how thanks for your sugegstion Mr.Kevin.Also thanks to CFD,CFD(2) and Dhandapani. Best Regards Pradeep |
Attempting to validate force code with 2D cylinder | andrewburns | OpenFOAM Running, Solving & CFD | 41 | January 2, 2008 23:55 |
Unable to open display | Alan | FLUENT | 5 | January 10, 2006 12:24 |
Error about open x display | tyrouser | Siemens | 1 | December 5, 2005 13:48 |
display error | davis | FLUENT | 1 | February 2, 2005 01:53 |
DISPLAY ERROR!! | Alex | FLUENT | 4 | February 12, 2004 09:40 |
