September 3, 2004, 04:15 |
problem with SCO X-Vision
i have HP machine (Pentium-IV 2,8GHz) with Windows XP Service Pack-1. I am not able to optimize the x-vision graphics. On running prostar, it gives a message "Profile already running" and does not progress any further. is there any additional requirement for proper installation of X-vision. Thanks in advance.
Prabodh |
September 7, 2004, 08:56 |
Re: problem with SCO X-Vision
What kind of graphics card is in the computer?
September 7, 2004, 23:52 |
Hi Leo, Its an on-board Intel(R) 82865G Graphics Controller. Prabodh
September 8, 2004, 08:43 |
You are a victim of a bug between xvision and Intel on-board graphics cards. To get around the problem, you can install Cygwin/X, a free xserver. It can be found at
http://x.cygwin.com Speaking from experience, make sure you READ CAREFULLY the installation guide BEFORE downloading and installing. When you install, you will need to add these two packages xorg-x11-base X-startup-scripts to the list of things to download and install. Also, you're current graphics card needs to be capable of a screen resolution of 1280x1024 dpi. If it isn't, Cygwin/X won't help you. |
September 9, 2004, 00:23 |
Hi Leo,
Thanks a lot. I have another query. X-vision is working fine on another PC with on-board graphics card (82845G Intel Graohics controller, on a 2.26GHz machine with Windows 200 Service Pack 4). Will Humming Bird's Exceed work with on-board graphics controller. Prabodh |
September 9, 2004, 01:46 |
Please the windows version of STAR-CD install Guide.
you need to modify your xvision. first . In the properties for xvision->server ->Backing store , function it. second. In the control panle -> vision of communcation -> transport -> Tcpip-unix ->enable transport. restart the Xvision . every will be good! |
September 10, 2004, 00:23 |
Tried all the suggested options. but nithing works. I had a similar problem on a celeron machine with on-board graphics card. By the way, Humming bird Exceed works perfectly and I am now using it for Star-CD.
September 10, 2004, 02:22 |
"Profile already running. "
This problem is a normal problem. I hope you can try the way i suggested. I have solver this problem several times. |
September 13, 2004, 14:57 |
#9 |
The bug does not occur with all on-board Intel cards. There is no list of which ones work/don't work. STAR-CD will work with exceed.
September 30, 2004, 10:46 |
#10 |
What tomosada siad is right. go to control panel open Viosn Properties, enable both the tcp transports click ok, before doing this kill the running xvision, if its running, now start ur program everything will be fine, if another user logs into this sytem to use the same application then u have to do the same in his account also, its only a per user one time setting.
October 24, 2004, 07:16 |
#11 |
October 24, 2004, 07:26 |
#12 |
Humming really work! Thank you!
Display Modes | |
Problem in Modelling Heat Transfer Problem | Deepak R | FLUENT | 1 | December 6, 2007 09:37 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
question about sco x vision | george | Siemens | 1 | January 22, 2007 09:47 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 3, 2006 23:37 |
