BÚG REPORT for CD
Old   September 17, 2004, 04:52
Default BÚG REPORT for CD
Piet
1. geometry plot on screen 2. open cell tool add shell in table5 and on screen 3. cset news type5 4. cplot 5. WARNING NO CELL SELECTED FOR PLOTTING ** ERROR ** NO ITEM SELECTED FOR PLOTTING
version linux 32 bit 3.2
It would be nice, if you could remove this programming mistake.
thx
Old   September 17, 2004, 09:03
Default Re: BÚG REPORT for CD
Brian
Two possible problems here, and they're not bugs.
1) (The really obvious) Do you have any shell cells of type 5? If not, you can't plot them.
2) (Most likely problem) When you use the command GETV, dummy shell cells are created for interpolation of data on the boundaries. These shells are marked as invisible, so they don't clutter your plots.
Unfortunately, when you first issue the GETW command, a flag is set that marks all shells created from that point on as invisible, i.e. they can't be plotted.
The solution is quite easy. BEFORE creating your new shells, issue the command CLRW. This clears the flag, and all subsequently created shells can be plotted in the same way.
Old   September 20, 2004, 02:45
PIET
THX
It works with CLRW
CFD report Sami FLUENT 0 April 15, 2008 11:09
Report > Discrete Phase > Report > How to commands Francesco Micchetti FLUENT 1 January 23, 2008 06:10
Please report this bug egp OpenFOAM Installation 5 December 8, 2006 12:56
need a report... CFD Student Main CFD Forum 0 April 3, 2006 15:33
Report Gabry FLUENT 2 December 5, 2003 09:38
