Tecplot ( moving mesh) & streamlines with Star-CD
Old   October 18, 2004, 03:37
Default Tecplot ( moving mesh) & streamlines with Star-CD
Funda
Hi everybody, I try to export results to tecplot from a moving mesh pstt file but Star-CD gives following error and close down:
/usr/local/bin/prostar: line 102: 32708 Segmentation fault ${STARDIR}/bin/pro-${PRODR} ${CMAP} ${BATCH} ${EZTOOL}
When reading the pstt file with no Moving Mesh option, there is no problem. Does anybody now, if there is a bug or not of Star-CD? How to export the moving mesh data to tecplot? I think there may be a memory problem but I do not know how to increase the memory that it uses when processing.
I also want to ask if there is a way to draw streamlines with Star-CD?
Merci...
Old   October 18, 2004, 20:55
Default Re: Tecplot ( moving mesh) & streamlines with Star
tomosada
I think this is because the PSTT file too big. You have to split the pstt when slover process.
You can also change the param.prp file to match the mesh size.
When you import file to tecplot, data will be seprate in to serveral zone with the time.
Getting Star-CCM+ results to tecplot 360 Nathan Siemens 3 April 4, 2017 14:18
sliding moving mesh with STAR-CD 4.06 ELYOR Siemens 1 June 30, 2008 08:54
Output data from STAR-CD to Tecplot Lee Siemens 0 June 5, 2006 12:58
Star-CD and Tecplot David Baker Siemens 1 April 19, 2006 08:02
STAR-CD, moving grid and streamlines Mohamed GUEROUACHE Main CFD Forum 1 September 13, 1999 13:33
