Parm.inc error when running analysis
Hi Guys
Wondering if you can help me. Im trying to run a 2D model at the moment, once the meshing is complete I try to set analysis options before writing .geom and.prob files then an error occurs saying no parm.inc file could be found? Does anyone know how I cen write a parm.inc file or where I can find it.. Thanks Chris |
Re: Parm.inc error when running analysis
Hello Chris,
I think if you go ahead and just write the *.geom file it should create the parm.inc. Also you might get errors in writting the geometry due to bad cells so I would make sure I have a perfect mesh before finalizing the problem file and setting up boundary conditions. Kevin |
Ok Kevin
Thanks for your help, will look at it now and try evaluate the problem regions... Chris |
A Param.inc error can be due to several reasons. I used to get a similar error when the license file for StarCD cud not be read!!!
