Compiling Error in prostar
I'm trying to use prostar to do a simulation. It's the first time with prostar and I don't have so much time so I run proam, I generated a trimmed mesh and then I followed Star-GUIDE to fill the other infos. At the end, I tryed to run the solver, but I got this message: --------------------------- close,volume2_3_f.drp FILE volume2_3_f.drp CANNOT BE CLOSED OR NOT OPEN PRO *> Message passing library: Sequential Linking double precision sequential executable "star-volume2_3_f.exe"... f77: unrecognized option `-N3' f77: unrecognized option `-N26' f77: unrecognized option `-N15' f771: Unrecognized option `-f' ###################################### WARNING: Command execution error. Please check screen output for details ###################################### starin.f compile error. Exiting starlink. ------------------------------------- Does anybody know which is the reason? I'm working in Linux with a GNU fortran compiler. Is it a problem related to my model or to the compiler (for example I have to set some particular variable or ?) ? Thank you in advance, Erika |
Re: Compiling Error in prostar
try using only prostar pre and post and simulate for less number of iter jus to see if it works.
It does't begin to simulate! It cannot compile!
I think that should be a problem not with Star CD but with the installation i guess. What OS r u runnin.
I'm using Linux; I don't know any more information...and net administrators are already gone away...I'll let you know tomorrow...thank you anyway... Erika |
GNU Fortran is not supported under Linux. You must use Absoft. It's all explained in the installation notes.
You need to use Absoft Fortran to compile
You have to install the correct version of Absoft. STARCD V3.22 supports Absoftv8.2.
