Mixing two chemicals in a t-shaped miser
Old   December 14, 2004, 07:10
Default Mixing two chemicals in a t-shaped miser
Toni Vainio
I have two inlets and one outlet in a t-shaped mesh. I would like to make say water enter inlet 1 and benzene to enter inlet two, and see how quickly they mix. Can someone tell me how I can specify inlet 1's liquid to be water and inlet 2 be benzene. (The thermophysical properties only allows me to specify one liquid.)
Thanks
Old   December 14, 2004, 08:11
Default Re: Mixing two chemicals in a t-shaped miser
Brian
Specify your "background" liquid as water, in the normal way, using Molecular Properties.
Create an additional scalar, and define it as Benzine using the built-in database. Make sure the influence is set to "Active".
Set the scalar boundary values to 0.0 at the water inlet, and 1.0 at the Benzine inlet.
Now make the density and viscosity, etc. "Multicomponent" in Molecular Properties. This will make the physical properties a function of the mixture.
S shaped duct francois Main CFD Forum 5 May 16, 2014 05:44
Wedge Shaped Hopper Arun FLUENT 0 December 31, 2007 06:27
Cross-Shaped Mixing Park, Jaehong FLUENT 0 March 10, 2004 23:07
Flow of chemicals through soil bed umesh FLUENT 3 May 29, 2003 19:55
S-Shaped circular duct! Ravi Kumar Main CFD Forum 5 August 15, 2001 10:32
